I will be using the Honeywell RLV4300A as my base unit. There are two circuit boards in this device, one high voltage board and a low voltage interface and control board. These are connected using a 4 pin header. No modifications should be needed to the high voltage board, which is good because I don't want to play with that. The existing low voltage board currently utilizes a Atmel ATmega169P processor, to control the power, display and 8 buttons.
My overall goal will be to replace the low voltage board with a custom design. This custom design should use the ESP8266 as the main processor, with custom code to emulate the existing functionality and enable remote control and configuration.
Jared Young
cyplesma
Daniel Garcia
Savo
Adam Demuri
