MSX protocard
An msx protoboard with eprom and basic data/address lines layout for easy and quick prototyping for MSX systems.
My MSX lacks any floppy disk controller and has no second slot for games... so I want to modify it, for that I have to learn the basics of MSX. And so, first project is to make some "universal" protoboards, that enable me to quickly prototype hardware. My plan is to make a few of these boards and build either some Homebrew game cards, a floppy controller, IDE controller or even a slotexpander. The PCB should get alott of prototype pins (wich currently are not there as you can see)
  • 1 × PCB The prototype board, could be replaced by selfmade one or none at all (dificult)
  • 1 × Capasitor (Value tbd)
  • 1 × Capasitor 1nF for EEPROM
  • The start
    codeasm11/17/2015 at 11:15 0 comments
    Ok, have started a couple of days ago and this is what I like to do:
    todo:
    • Wire the selection header (for rom size and location selection, as seen on more msx protoboards/cardrigde cards)
    • Dont use autoroute, make it look clean (wich I hope make it more easy to mod lines if needed)
    • Add proto areas (how to cleanly add this to eagle?)
    • Manufacture the boards at a cheap fab. (all files will be availeble, because I got all info and symbols for free aswell)
    • Test a MSX mapper like Asci
View project log
  • 1
    Step 1
    Get PCB
  • 2
    Step 2
    Get Items like EEProm (preprogrammend or empty)
  • 3
    Step 3
    Look at the parts and enjoy
View all 7 instructions
