PCB's are in
A project log for Atmega328 programmer/ftdi backpack board
It allows you to easily hook up a atmega328 chip so it can programmed or connect a serial adaptor and still leave room on the bread board
facelessloserfacelessloser 12/01/2015 at 17:350 Comments
My PCB's came in this morning, only took 14 days which is quite quick for oshpark to the UK. I did find one error with my boards, the holes for pins 9 and 10 were .76mm instead of .80mm a bit of persuasion and the I got the male pins to fit.
I'm waiting on my new soldering iron since my old one died on me :(
