electric hurdy gurgy synthy
self powered by turning a crank
no batteries required
This is a three parts synthy, combining the following
Drones
always on when turning (probably 40106)
Melodic keyboard
needs a keyboard of some sort
rhythm
with input from dynamo or encoder wheel on crank
will also need a good generator / dynamo - 3 phase brushless maybe?
View all 2 project logs
Frank Buss wrote 04/23/2018 at 05:40 point
Good luck with the self powering part. You would need to buffer at least some of the energy, because sometimes there are pauses, see e.g. at 0:45:
https://www.youtube.com/watch?v=rGfnlO_z97E
and power could be a problem for a speaker. Also forward/backward movements are possible, see at 2:13 and 3:47, and faster movements sound different, see 2:53:
https://www.youtube.com/watch?v=2Q4mKo9gBF4
so you should measure the speed and direction of the crank.
Dr. Cockroach wrote 03/12/2018 at 15:39 point
Sounds interesting Dave. I will be watching for more :-)
