All vacuum tube calculator
A project log for Make your own 7 segment displays..With Neon light
Using a 3D printed frame and some Ne-2 neon lamps you can make your own impressive seven segment displays.
castvee8castvee8 03/27/2018 at 01:526 Comments
This machine is not finished but far enough along to show some basic operations and the massive amount of hefty components used in its construction. Lots of tubes and transformers!
It is rather long and boorish as well as not even having all the neon digits attached and operating but the solution displays are functional. The input numbers are entered on the slide switches.
The gate logic was all done with pentodes. Its a big ole wiring mess as it is point to point wired on the underside of the sockets.
The large tubes on the back are the power rectifier and VR regulator. The display segments were decoded using 6D6A-V Diodes, which are small vacuum tube diodes I got from Russia. They are jumpered across the seven segments lighting each segment required for that digit.
Here is a photo:
They are used just like a conventional diodes except you have to supply filament voltage. One of the large power transformers mounted to the side of this machine feeds these the filament voltage required.
To decode the digit 0 for example you would need 6 diodes-segments a-f all get a diode jumpered to form the digit(all except the center segment g). To decode all digits from 0-9 requires more than 30One good thing about these tubes is they can be laid flat against the pcb to reduce space and ease layout for connections. This uses more pcb space but in this type of vintage construction space is going to get used anyway! They have nice long flexible leads. 2 are for filament and then the anode and cathode.
Here is an example I made for using solid state diodes to decode the display:
After the decoding diode are connected you end up with a ten connection devise just like a conventional nixies.
castvee8 wrote 03/27/2018 at 14:58 point
Just a simple diode array-I added it in the description. Hope you like it.
Yann Guidon / YGDES wrote 03/27/2018 at 15:36 point
A vacuum diodes array. For decoding 7 segments.
OK you're really overkilling it, aren't you ? :-P
Yann Guidon / YGDES wrote 03/27/2018 at 09:00 point
You'll have to explain how you do the 7-segments decoder :-D
castvee8 wrote 03/27/2018 at 13:13 point
Really? I am pretty sure nobody is ever going to do it again......And if I bore them to tears they may not want to come back.,,,,But Ok.....
Yann Guidon / YGDES wrote 03/27/2018 at 14:52 point
Please ;-) You know I love 7-segments decoders ;-)
Diode array ? logic ? Magic ? Punched card ?...
Dr. Cockroach wrote 03/27/2018 at 23:39 point
Yes, please. I would like to know too :-)
