When you're using a Netduino, don't...
- Drop a wire across the 'clear flash' contacts
- Send it TCP connection requests before it's booted
- Try to allocate 32768 bytes three times over
- Let it crash with the elements at 100%
- Try to low-side switch something being fed with 9v
- Forget the pull-up resistors on I²C
- Use SPI slave devices that pull up on the clock line
- Short +9v to the +3.3v rail. You'll let out the magic smoke, and nothing you did above will matter now.
