Inspired by the hashkey, but a more flexible diy opensource solution which could be built at home some key ideas:
- Cap and case 3D-printable (will publish files) on mostly every 3D-Printer
- Small PCB with all electric components including:
- USB Microcontroller (still not sure which)
- USB connector - exchange you wire to any color and length
- optional RGB LED for some colorful backlight
- Switch (perhaps a mechanical cherry-style one)
And here some sketch of it:
Alex
