Well it has been ages, but...
A project log for Small Multicell USB Type C Charger
USB Type C has up to 100W of charging capability, perfect for a multicell charger
chris-hamiltonChris Hamilton 09/06/2019 at 20:381 Comment
I am putting a variation of the design up on github - https://github.com/FyberLabs/usb-motor/
It is a specific application that was requested awhile back.  I will be making a few variants including a powerbank, drone charger, and a brushless controller similar to this one.  The design is a bit larger, but it can be shrunk down to about the same size.  The original design would require 12-20V from the USB source.  Now it will be able to accept 5-20V for 1-4 cells in the design.  The design can obviously be reduced by a specified cell count and application.
cameraloops wrote 12/25/2019 at 22:32 point
Hi Would like one of this board pre built, Do you have any for sale?
