Cutting aluminium for a tracked rover
A project log for Basic DIY CAM 2018
Build computer controlled manufacturing tools from commonly available materials.
Norbert HeinzNorbert Heinz 01/19/2019 at 07:080 Comments
As a test run for my CNC v3.2.2 I have cut 3mm aluminium sheets to build a new, tracked robot:
While cutting the parts I found some minor issues with the linear drives and I have ideas how to fix those problems, so my CNC project goes on...
