First matrix PCBs soldered
A project log for reDOT_Matrix
A alternative approach to create a multi digit 5x7 LED Matrix Display
alexAlex 04/12/2018 at 21:460 Comments
If you follow me on twitter (@tinyledmatrix) you could already know these pictures. I soldered the first five matrix PCBs. At least a quick diode test with the multimeter was positive. PCBs for the main PCB should arrive tomorrow, if the tracking is correct. So more soldering work to do on the weekend!
