Scan Matching and Registration
A project log for QuadRotor testBed for localization and mapping
I am trying to build a test bed for trying out localization and mapping algorithms.
int-smartint-smart 03/14/2018 at 01:250 Comments
ICP (Iterative closest point) is a popular range data processing method that can be used for range registration. Given two sets of slightly overlapping point clouds the ICP computes the registeration of one scan over the other in an iterative fashion.
Mathematically we can construct the problem as:
Given two point setwe need to find the translation and rotation that
If the correct correspondances are known, we can calculate the alignment using SVD. It can be done using first subtracting the value of the center of mass of the two point clouds from the points in the set and then taking the SVD of the accumulation matrix defined by:The rotation matrix is given by
The registeration algorihtm is briefly described in the following:
