• IO.h
    jlbrian711/29/2015 at 17:50 0 comments
    ;#pragma once
    ; CIS - 261
    ; IO.H -- header file for I / O macros
    ; 32 - bit version for flat memory model
    .NOLIST; turn off listing
    .386
    EXTRN  itoaproc : near32, atoiproc : near32
    EXTRN  dtoaproc : near32, atodproc : near32
    EXTRN  inproc : near32, outproc : near32
    EXTRN  szlenproc : near32
    itoa        MACRO  dest, source, xtra;; convert integer to ASCII string
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    push   ebx;; save EBX
    mov    bx, source
    push   bx;; source parameter
    lea    ebx, dest;; destination address
    push   ebx;; destination parameter
    call   itoaproc;; call itoaproc(source, dest)
    pop    ebx;; restore EBX
    ENDM
    atoi        MACRO  source, xtra;; convert ASCII string to integer in AX
    ;; offset of terminating character in ESI
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    push   ebx;; save EBX
    lea    ebx, source;; source address to EBX
    push   ebx;; source parameter on stack
    call   atoiproc;; call atoiproc(source)
    pop    ebx;; parameter removed by ret
    ENDM
    dtoa        MACRO  dest, source, xtra;; convert double to ASCII string
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    push   ebx;; save EBX
    mov    ebx, source
    call   dtoaproc;; call dtoaproc(source, dest)
    ENDM
    atod        MACRO  source, xtra;; convert ASCII string to integer in EAX
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    lea    eax, source;; source address to EAX
    push   eax;; source parameter on stack
    call   atodproc;; call atodproc(source)
    ENDM
    output      MACRO  string, xtra;; display string
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    push   eax;; save EAX
    lea    eax, string;; string address
    push   eax;; string parameter on stack
    call   outproc;; call outproc(string)
    pop    eax;; restore EAX
    ENDM
    input       MACRO  dest, length, xtra;; read string from keyboard
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    push   ebx;; save EBX
    push   ebx;; dest parameter on stack
    mov    ebx, length;; length of buffer
    push   ebx;; length parameter on stack
    call   inproc;; call inproc(dest, length)
    ENDM
    szlen       MACRO  string, xtra;; get string length
    IFB
    .ERR
    EXITM
    ENDIF
    IFNB
    .ERR
    EXITM
    ENDIF
    call   szlenproc;; call szlenproc(string)
    ENDM
    .NOLISTMACRO; suppress macro expansion listings
    .LIST; begin listing
    This is not my code! this is from http://www.c-jump.com/bcc/c261c/CIS261syllabus.html
  • IO.asm
    jlbrian711/29/2015 at 17:49 0 comments
    ; CIS-261
    ; implementation of I/O procedures called by macros in io.obj
    ; flat memory model version
    .386
    .MODEL FLAT
    PUBLIC itoaproc, atoiproc, dtoaproc, atodproc, outproc, inproc, szlenproc
    .CODE
    ; itoaproc(source, dest)
    ; convert integer (source) to string of 6 characters at given destination address
    itoaproc    PROC   NEAR32
                push   ebp                  ; save base pointer
                mov    ebp, esp             ; establish stack frame
                push   eax                  ; Save registers
                push   ebx                  ;   used by
                push   ecx                  ;   procedure
                push   edx
                push   edi
                pushf                      ; save flags
                mov    ax, [ebp+12]        ; first parameter (source integer)
                mov    edi, [ebp+8]        ; second parameter (dest offset)
    ifSpecial:  cmp    ax,8000h            ; special case -32,768?
                jne    EndIfSpecial        ; if not, then normal case
                mov    BYTE PTR [edi],'-'  ; manually put in ASCII codes
                mov    BYTE PTR [edi+1],'3'  ;   for -32,768
                mov    BYTE PTR [edi+2],'2'
                mov    BYTE PTR [edi+3],'7'
                mov    BYTE PTR [edi+4],'6'
                mov    BYTE PTR [edi+5],'8'
                jmp    ExitIToA            ; done with special case
    EndIfSpecial:
                mov    dx, ax              ; save source number
                mov    al,' '              ; put blanks in
                mov    ecx,5               ;   first five
                cld                        ;   bytes of
                rep stosb                  ;   destination field
                mov    ax, dx              ; copy source number
                mov    cl,' '              ; default sign (blank for +)
    IfNeg:      cmp    ax,0                ; check sign of number
                jge    EndIfNeg            ; skip if not negative
                mov    cl,'-'              ; sign for negative number
                neg    ax                  ; number in AX now >= 0
    EndIfNeg:
                mov    bx,10               ; divisor
    WhileMore:  mov    dx,0                ; extend number to doubleword
                div    bx                  ; divide by 10
                add    dl,30h              ; convert remainder to character
                mov    [edi],dl            ; put character in string
                dec    edi                 ; move forward to next position
                cmp    ax,0                ; check quotient
                jnz    WhileMore           ; continue if quotient not zero
                mov    [edi],cl            ; insert blank or "-" for sign
    ExitIToA:   popf                       ; restore flags and registers
                pop    edi
                pop    edx
                pop    ecx
                pop    ebx
                pop    eax
                pop    ebp
                ret    6                   ;exit, discarding parameters
    itoaproc    ENDP
    ; dtoaproc(source, dest)
    ; convert double (source) to string of 11 characters at given offset in DS (dest)
    dtoaproc    PROC   NEAR32
                push   ebx                 ;   used by
                push   edx
                push   edi
                pushf                      ; save flags
                mov    eax, [ebp+12]         ; first parameter (source double)
                mov    edi, [ebp+8]          ; second parameter (dest addr)
    ifSpecialD: cmp    eax,80000000h       ; special case -2,147,483,648?
                jne    EndIfSpecialD       ; if not, then normal case
                mov    BYTE PTR [edi+1],'2' ;   for -2,147,483,648
                mov    BYTE PTR [edi+2],'1'
                mov    BYTE PTR [edi+3],'4'
                mov    BYTE PTR [edi+4],'7'
                mov    BYTE PTR [edi+5],'4'
                mov    BYTE PTR [edi+6],'8'
                mov    BYTE PTR [edi+7],'3'
                mov    BYTE PTR [edi+8],'6'
                mov    BYTE PTR [edi+9],'4'
                mov    BYTE PTR [edi+10],'8'
                jmp    ExitDToA            ; done with special case
    EndIfSpecialD:
                mov    edx, eax            ; save source number
                mov    ecx,10              ;   first ten
                cld                        ;   bytes of
                mov    eax, edx            ; copy source number
    IfNegD:     cmp    eax,0               ; check sign of number
                jge    EndIfNegD           ; skip if not negative
                neg    eax                 ; number in EAX now >= 0
    EndIfNegD:
                mov    ebx,10              ; divisor
    WhileMoreD: mov    edx,0               ; extend number to doubleword
                div    ebx                 ; divide by 10
                cmp    eax,0               ; check quotient
                jnz    WhileMoreD          ; continue if quotient not zero
    ExitDToA:   popf                       ; restore flags and registers
                pop    edi
                pop    edx
                pop    ecx
                pop    ebx
                pop    eax
                pop    ebp
                ret    8                   ;exit, discarding parameters
    dtoaproc    ENDP
    ; atoiproc(source)
    ; Procedure to scan data segment starting at source address, interpreting
    ; ASCII characters as an integer value which is returned in AX.
    ; Leading blanks are skipped.  A leading - or + sign is acceptable.
    ; Digit(s) must immediately follow the sign (if any).
    ; Memory scan is terminated by any non-digit, and the address of
    ; the terminating character is in ESI.
    ; The following...
  • I/O
    jlbrian711/29/2015 at 17:47 0 comments
    ; CIS-261
    ; M08.ASM
    ; Demo program of IO.H and IO.ASM usage
    ; @topic W080093 IO.H and IO.ASM usage demo
    ; @brief Console Input/Output OUTPUT, INPUT, SZLEN, DTOA, ITOA, ATOI usage
    .386					; Tells MASM to use Intel 80386 instruction set.
    .MODEL FLAT				; Flat memory model
    option casemap:none		; Treat labels as case-sensitive
    INCLUDE IO.H			; header file for input/output
    .CONST					; Constant data segment
    	intro1				BYTE	"Jeramy Brian", 0
    	intro2				BYTE	"Assignment M08", 0
    	intro3				BYTE	"1. Inputs two 8-bit unsigned integers from the user, calculates the sum of the two numbers, and prints the result on the screen.", 0
        addPrompt1			BYTE    "Please enter two numbers in the range [0, 255], in the format '1 + 2': ", 0
        addPrompt2			BYTE    "Would you like to add more numbers (y/N): ", 0
    	addError1			BYTE	"ERROR :: OVERFLOW :: (BYTE, DWORD) :: (", 0
    	addError2			BYTE	"ERROR :: This number is too big. ::", 0
    	intro4				BYTE	"2. Inputs two 32-bit signed integers from the user, calculates their difference, and prints the result.", 0
        subPrompt1			BYTE    "Please enter two numbers in the range [-2147483648, 2147483647], in the format '1 - 2': ", 0
    	subPrompt2			BYTE    "Would you like to subtract more numbers (y/N): ", 0
    	subError1			BYTE	"ERROR :: OVERFLOW :: (SDWORD) :: (", 0
    	exitPrompt			BYTE	"Press enter to exit...", 0
    	ENDL				BYTE    13, 10, 0
    	equals				BYTE    " = ", 0
    	subtract			BYTE	"-", 0
    	addition			BYTE	"+", 0
    	genError			BYTE	"ERROR :: That entry could not be understood. :: ", 0
    	contPrompt			BYTE	"Press 'Enter' to continue...", 0
    	errorFrm1			BYTE	", ", 0
    	errorFrm2			BYTE	")", 0
    	numbers				BYTE	"0123456789", 0	;Second 0 is a place holder
    	space				BYTE	" ", 0
    .STACK 100h				; (default is 1-kilobyte stack)
    .DATA					; Begin initialized data segment
        dtoa_buffer			BYTE    11 DUP (?), 0
        atoa_buffer			BYTE    6  DUP (?), 0
    	addBuffer			BYTE    12 DUP (?)
    	add1Str				BYTE	3 DUP (?), 0
    	add1				BYTE	?
    	add2Str				BYTE	3 DUP (?), 0
    	add2				BYTE	?
    	addAns				BYTE	?
    	addAnsStr			BYTE	3 DUP (?), 0
    	addOFAnsStr			BYTE	6 DUP (?), 0
    	addErrAns			DWORD	?
    	;BOOL Value for code reuse
    	isSub				BYTE	0
    	subBuffer			BYTE	26 DUP (?)
    	sub1Str				BYTE	11 DUP (?)
    	sub1				SDWORD	?
    	sub2Str				BYTE	11 DUP (?)
    	sub2				SDWORD	?
    	subAns				SDWORD	?
    	subAnsStr			BYTE	26 DUP (?)
    	tmpAddr				DWORD	?
    	numCounter			DWORD	0
    	strCounter			DWORD	0
    	strLength			DWORD	0
    	numCounter1			DWORD	0
    	numCounter2			DWORD	0
    	ansCounter			DWORD	0
    	tmpCounter			DWORD	0
    	tmpStr				BYTE	?
    	doItAgainCntr		DWORD	0
    	doItAgainBuffer		BYTE	6 DUP (?)
    .CODE					; Begin code segment
    _main PROC				; Beginning of code
        output  intro1				; My name
    	output	ENDL				; Start New Line
    	output	intro2				; The assignment
    	output	intro3				; First part of assignment
    addFunc:
    	output	addPrompt1																; Give user instructions
        input   addBuffer, 12															; ...read zero to 10 ASCII characters
    	szlen	addBuffer																; get the length of the input
    	mov		strLength, eax															; put the length in a variable
    	mov		tmpCounter, eax															; set the length to a variable that is going to be decrimented
    	mov		tmpAddr, OFFSET add1Str													; set the address of add1Str to a temp value that can be incremented
    	lea		edx, ds:[addBuffer]														; load the address of the addBuffer into edx
    	jmp		compAdd																	; jump to the comp add 'function'  this is to compare the entries on the buffer string to values we are looking for
    	;make sure we have a '+' symbol
    	compAdd:
    		mov		al, addition														; load the addition value into eax
    		mov		bl, [edx]															; move the value stored in the eax register to bl
    		cmp		al, bl															...
