IO.h
A project log for Assembly
This will be useless except for reference.
jlbrian7jlbrian7 11/29/2015 at 17:500 Comments
;#pragma once
; CIS - 261
; IO.H -- header file for I / O macros
; 32 - bit version for flat memory model
.NOLIST; turn off listing
.386
EXTRN  itoaproc : near32, atoiproc : near32
EXTRN  dtoaproc : near32, atodproc : near32
EXTRN  inproc : near32, outproc : near32
EXTRN  szlenproc : near32
itoa        MACRO  dest, source, xtra;; convert integer to ASCII string
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
push   ebx;; save EBX
mov    bx, source
push   bx;; source parameter
lea    ebx, dest;; destination address
push   ebx;; destination parameter
call   itoaproc;; call itoaproc(source, dest)
pop    ebx;; restore EBX
ENDM
atoi        MACRO  source, xtra;; convert ASCII string to integer in AX
;; offset of terminating character in ESI
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
push   ebx;; save EBX
lea    ebx, source;; source address to EBX
push   ebx;; source parameter on stack
call   atoiproc;; call atoiproc(source)
pop    ebx;; parameter removed by ret
ENDM
dtoa        MACRO  dest, source, xtra;; convert double to ASCII string
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
push   ebx;; save EBX
mov    ebx, source
call   dtoaproc;; call dtoaproc(source, dest)
ENDM
atod        MACRO  source, xtra;; convert ASCII string to integer in EAX
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
lea    eax, source;; source address to EAX
push   eax;; source parameter on stack
call   atodproc;; call atodproc(source)
ENDM
output      MACRO  string, xtra;; display string
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
push   eax;; save EAX
lea    eax, string;; string address
push   eax;; string parameter on stack
call   outproc;; call outproc(string)
pop    eax;; restore EAX
ENDM
input       MACRO  dest, length, xtra;; read string from keyboard
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
push   ebx;; save EBX
push   ebx;; dest parameter on stack
mov    ebx, length;; length of buffer
push   ebx;; length parameter on stack
call   inproc;; call inproc(dest, length)
ENDM
szlen       MACRO  string, xtra;; get string length
IFB
.ERR
EXITM
ENDIF
IFNB
.ERR
EXITM
ENDIF
call   szlenproc;; call szlenproc(string)
ENDM
.NOLISTMACRO; suppress macro expansion listings
.LIST; begin listing
This is not my code! this is from http://www.c-jump.com/bcc/c261c/CIS261syllabus.html
