LM2596 Module Placeholder
A project log for Eagle Libraries
This will be a repository for my current custom Eagle Libraries. (Eagle 7.2)
greg-duckworthGreg Duckworth 01/21/2016 at 21:374 Comments
This is a place holder for the LM2596 Buck converter bought on eBay. Basically just an easy way to prototype in Eagle.
The set pin is the 'centre' tap of the pot and it means that I can control the voltage output of the module with an input voltage.
Datasheet is here:
LM2596
My eagle library is here:
https://www.dropbox.com/scl/fi/bbfiz4qlf014xtcbf2eu2/LM2596S_Module.lbr?rlkey=qa303pi5n2sc5krev0tjw8kst&dl=0
Bert van den Berg wrote 04/14/2024 at 00:09 point
Does anyone know how many times the CH552 can be reprogrammed before it fails?
Greg Duckworth wrote 04/04/2024 at 18:53 point
LM2596 Eagle Library has been updated
evanhuang117 wrote 06/04/2016 at 18:54 point
404 error. Could you reupload the file? I really need this for a project.
aditya unde wrote 12/08/2017 at 08:33 point
did u get this project?
