Quick and Nasty Tube Power Supply
Back to overview
A simple way to make a transformer for a vacuum tube project
Martin wrote 07/11/2017 at 06:42 point
Quite some work and you need to buy/get two identical transformers. And they have to be of a construction with two bobbins/coil formers. OK, it is more efficient than connecting the secondaries of the two transformers together-
Is it really that difficult to source the right transformer at the beginning?
