Zmodo - Local Controller
Zmodo have some cool cameras! This project is about reversing protocols / bins of all things zomodo to bypass the cloud.
This camera is really cool but is uses some "cloud app" for all video to be uploaded to. I would like to create a NodeJS server for this to bypass sending all my video / audio to China :) This is just a place for me to dump files and notes. If you want to help check out the main App3518 (which is the cpu Hi3518C) binary and help start to reverse it.
All files for this project are in the dropbox link. The main "App" file is App3518 and it is in the Dropbox link. This file is also the local webserver. It is responsible to posting video data to the MeShare website. You can downlod the MeShare app for IOS and Android as well if you would like to poke around in that.
What I am hoping for is some others that want to use this camera to get involved in the reversing of the networking protocol. I am not 100% certain.. But it might make more sense to place a different "app" on the device that we write and can post all the video data straight to our server code.
Amazon sells these cameras for around $38 here:
http://www.amazon.com/gp/product/B00ZZ4HX1K
Cameras known to run the same software (perhaps different hardware)
  1. Zmodo ZH-IXY1D
  2. Zmodo ZM-SH75D0001
If you know of a Zmodo camera running the same version (or contacting the same cloud servers) leave a comment and I will add them to the list. The App3518 has the shasum of ba5fa306d519c57124f9de96a1f007f0. App3518 is the main binary that runs on these Zmodo* cameras.
zmodoboot.txt
Out of the box boot log. This is before connecting to a wireless network.
plain - 49.00 kB - 01/16/2016 at 03:27
Download
zmodowireless.txt
Log showing the wireless connection process during and after setup.
plain - 28.64 kB - 01/16/2016 at 03:27
Download
  • Dumping the MTD Partitions
    ril3y01/21/2016 at 03:21 5 comments
    I went ahead and dumped the files to the Dropbox for the MTD partitions.
    https://www.dropbox.com/sh/adups6kczg65138/AACquDl-FP1ZT0KB1yB-4aGia?dl=0
    # cat /proc/mtd
    dev: size erasesize name
    mtd0: 00040000 00010000 "boot"
    mtd1: 000c0000 00010000 "config"
    mtd2: 00480000 00010000 "rootfs"
    mtd3: 00a80000 00010000 "app"
    More to come....
  • Initial rooting (or read that as loggin in) and poking around
    ril3y12/02/2015 at 19:16 1 comment
    There is a 3 pad test point on the other size of the main board. It is 3v3 ttl serial. tx rx gnd. Solder a few tiny wires to each pad then hook up to a ttl 3v3 usb to serial ( I use the prolific ones) and open a serial terminal (coolterm etc) 115200 8N1. I did place a dab of hot glue to hold the wires in place as to not pull the test point's pads right off of the pcb. I forgot to take a picture of it first. I have another camera on order and will post some pics when it gets in.
    This will drop you to a root shell.... Heres some boot messages.. The full boot messages are in the dropbox link.
    U-Boot 2010.06 (Apr 28 2015 - 09:46:30)
    Check spi flash controller v350... Found
    Spi(cs1) ID: 0x01 0x20 0x18 0x4D 0x01 0x80
    Spi(cs1): Block:64KB Chip:16MB Name:"S25FL129P1"
    MMC:   MMC FLASH INIT: No card on slot!
    In:    serial
    Out:   serial
    Err:   serial
    No mmc storage device found!
    Hit any key to stop autoboot:  1 ... 0
    16384 KiB hi_sfc at 0:0 is now current device
    cramfs load file : /boot/hikernel
    ### CRAMFS load complete: 2409600 bytes loaded to 0x82000000
    ## Booting kernel from Legacy Image at 82000000 ...
       Image Name:   hilinux
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2409536 Bytes = 2.3 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    There is a really annoying feature that they felt the need to leave in place. All print statements from ./App3518 program seem to spit out to the tty. And its a very chatty program. However it does give you a glimpse into some of the communications with the "MeShare" streaming video service. Observe....
    Dec  2 14:02:09 <P2P>: web.cpp[471]web_report_upnp:recv:{"result":"ok","data":[],"addition":""}
    Dec  2 14:02:09 <P2P>: device_operation.cpp[744]p2p_send_cover_pic:begin upload cover picture for channel[0]...
    Dec  2 14:02:09 <P2P>: web_task.cpp[42]SetUrl:http://192.241.59.218:80/factorydevice/picture_report
    Dec  2 14:02:09 <P2P>: web_task.cpp[83]AddPostString:tokenid:p4yL5zwYSQRL8vcCNUbx9v12bmKcQF
    Dec  2 14:02:09 <P2P>: web_task.cpp[83]AddPostString:channel:0
    Dec  2 14:02:09 <P2P>: web_task.cpp[93]AddPostPicture:image_name:/tmp/cover.jpg
    Dec  2 14:02:09 <P2P>: web.cpp[402]web_report_picture:recv:{"result":"ok","data":"","addition":""}
    Dec  2 14:02:09 <P2P>: device_operation.cpp[942]p2p_is_timezone_set_by_meshare:timezone America/New_York, America/New_York
    Dec  2 14:02:09 <P2P>: web_task.cpp[42]SetUrl:http://192.241.59.218:80/factorydevice/gettimezone?tokenid=p4yL5zwYSQRL8vcCNUbx9v12bmKcQF
    Dec  2 14:02:09 <P2P>: web_task.cpp[252]SetConnectTimeout:[10]
    Dec  2 14:02:09 <P2P>: web.cpp[425]web_get_timezone:recv reply:{"result":"ok","offset_seconds":"-18000"}
    Dec  2 14:02:09 <P2P>: web.cpp[434]web_get_timezone:get timezone:-18000
    Dec  2 14:02:09 <P2P>: device_operation.cpp[905]p2p_set_timezone_offset[1170719936]
    Dec  2 14:02:11 <P2P>: p2p_sip.cpp[148]keep_alive_timer_func:keep alive timeout, resend !
    Dec  2 14:02:11 <P2P>: p2p_sip.cpp[120]send_keep_alive:send_keep_alive:{ "MethodName": "Option.update", "TokenId": "p4yL5zwYSQRL8vcCNUbx9v12bmKcQF", "DevId": "ZMD00ID02206860", "UserType": 2, "Interval": 90 }
    Dec  2 14:02:11 <P2P>: p2p_sip.cpp[40]p2p_keep_alive_cb:reply:{ "ResultCode": 0, "ResultReason": "ok", "CmuId": 1001000000 }
    The program generating all of these print statements is App3518 which I tftp'ed off of the device and posted in the dropbox link. There is also a message file which I am unclear of what it is doing.
    ril3ys-MBP:Zmodo Reversing ril3y$ file message App3518
    message: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), stripped
    App3518: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), stripped
View all 2 project logs
philcolbourn wrote 04/29/2016 at 12:16 point
ZH-IZV15-WAC
00 91 command seems to report camera routing table
00000000  55 55 aa aa fc cc 00 00  00 00 00 91 00 00 00 00
00000010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00000030  00 00 00 00 00 00 00 00  00 00 00 00 GATEWAY--IP
00000040  00 00 00 00 CAMERA---IP  NETWORKMASK GATEWAY--IP
00000050  CAMERA--MAC--ADDR 01 00  00 00 00 00 00 00 00 00
00000060  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00000210  00 00 00 00 00 00 00 00  00 00 00 00 19 00 00 00
00000220  01 00 00 00 01 01 CAMERA----IP NETWORKMASK GATEW
00000230  AY-IP CAMERA--MAC--ADDR  GATEWAY--IP 00 00 00 00
00000240  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
philcolbourn wrote 04/27/2016 at 15:21 point
ZH-IZV15-WAC
Discovered by accident that I can change its MAC address. After which it seems to restart and obtain a new IP address.
009c to set MAC
019c to read MAC
I tried to change MAC address to 'Coffee'
echo -ne '\x55\x55\xaa\xaa\x06\x00\x00\x00\x00\x00\x00\x9cCoffee' | netcat -w 5 10.1.0.96 8000 | hexdump -C
00000000  55 55 aa aa 04 00 00 00  00 00 00 9c 00 00 00 00  |UU..............|
00000010
<camera reset - lookup new IP address - now 10.1.0.97>
echo -ne '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x01\x9c' | netcat -w 5 10.1.0.97 8000 | hexdump -C
00000000  55 55 aa aa 06 00 00 00  00 00 01 9c 44 6f 66 66  |UU..........Doff|
00000010  65 65                                             |ee|
00000012
So, I got Doffee, not Coffee - it seems to add 1 to first byte of MAC address
fleshinachair wrote 04/26/2016 at 21:35 point
Well done for setting up this project. I found this page randomly as I own 2 zmodo cameras (indoor and outdoor model) but theyve decided that they can not or will not support email alerts anymore - I think maybe cos they want to upsell the cloud features instead. If anyone has a way of fixing this I'd be most interested as would a large number of people on their forums. I'm not a programmer but will follow this avidly!
http://community.zmodo.com/t/email-alerts-suddenly-stopped/2018/129
Hajo wrote 04/15/2016 at 10:19 point
Some more details:
(might be interesting sometime? - maybe not)
I put a complete directory/file listing into dropbox:
# ls / -l -R
https://www.dropbox.com/s/ti1kvy2ljafthtg/directory.txt?dl=0
# df
Filesystem           1K-blocks      Used   Available  Use%     Mounted on    Access
/dev/root                    7040      7040                0  100%     /                        read only
devtmpfs                  15968             4        15964   0%        /dev                  read/write
tmpfs                        16032           36        15996   0%        /tmp                  read/write
/dev/mtdblock3       10752       6872         3880  64%       /app                  read/write
/dev/mtdblock1            768         216           552  28%        /config              read/write
tmfs                          16032            0        16032   0%         /system             read/write
# lsusb
Bus 001 Device 001: ID 1d6b:0002     -> Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001     -> Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0bda:8179    - > Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Hajo wrote 04/06/2016 at 21:05 point
Hi all,
I own a Zmodo ZH-IXY1D as well.
It runs Stock Firmware 7.4.0.16
Model: ZM-SH75D001-WA (shown in Device Parameters)
Hardware Version: 799990304
Some more details from WebUI:
Whether to support the intercom: YES
Whether to support local Storage: NO
Whether to support Onvif: NO
Whether to support PT: NO
Whether to support Zoom: NO
Whether to support Wifi: YES
Telnet with root access works (root/no password).
___________________________________________
# cat /proc/cpuinfo
Processor       : ARM926EJ-S rev 5 (v5l)
BogoMIPS        : 218.72
Features        : swp half thumb fastmult edsp java
CPU implementer : 0x41
CPU architecture: 5TEJ
CPU variant     : 0x0
CPU part        : 0x926
CPU revision    : 5
Hardware        : hi3518
____________________________________________
# uname -mrs
Linux 3.0.8 armv5tejl
# cat /proc/version
Linux version 3.0.8 (harvey@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #2 Thu Apr 16 10:08:52 CST 2015
# mount
rootfs on / type rootfs (rw)
/dev/root on / type cramfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=15968k,nr_inodes=3992,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
tmpfs on /tmp type tmpfs (rw,relatime)
/dev/mtdblock3 on /app type jffs2 (rw,relatime)
/dev/mtdblock1 on /config type jffs2 (rw,relatime)
tmfs on /system type tmpfs (rw,relatime)
______________________________________________
The Hardware is not too bad, so I want to setup a cross-compiler to bring some software on that CAM.
http://events.linuxfoundation.org/sites/events/files/slides/Shuah_Khan_cross_compile_linux.pdf
Goals:
1a. ) Create local snapshot on camera and move it to a ftp server (automatic)
1b.) JPEG/MJPEG Streaming via port 80 (local folder -> /app/dvr)
2a.) The Cam should initate the rtsp-stream (FFMPEG/H264) on its own.
2b.) The stream should stop for ~1 Second after eg. 5 Minutes, and restart automaitcally, to have constant stream for NVR
Additional input welcome!
BR
Hajo
Neil Cherry wrote 05/11/2016 at 03:19 point
Thanks for the pdf. I'm not ready to setup the cross-compiler yet but I hope to later this summer. Still very busy with other HA projects. Glad to see others still playing. :-)
I've been using the same perl code to pull images (not streams) from other cameras (Amcrest and Foscam).
ril3y wrote 08/25/2016 at 22:01 point
Agree with @Neil Cherry I am planning on picking this back up.  I found the SDK to build the image.  I have not had time to play with it.  Now that winter is coming... I plan on getting these things working to my network not the cloud!
les.v2 wrote 03/03/2016 at 17:20 point
Hi All,
Just to inform you that I found how to get HD or SD stream.
I reuse things already find by the team ;-) that's why you will recognize your commands ;-)
1) The command to do screenshot "HD"  (tested on raspberry pi 2): PNG image data, 1280 x 720, 8-bit/color RGB, non-interlaced :
time ( echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x50' | netcat -w 2 192.168.0.38 8000 | avconv -i pipe:0 -q:v 1 -vframes 1 HD.png &>/dev/null )
Time of capture on my local network : 1.163s
and the command to check generation and format:
2) The command to do screenshot "SD"  (tested on raspberry pi 2) : PNG image data, 320 x 240, 8-bit/color RGB, non-interlaced
time ( echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x02\x90' | netcat -w 2 192.168.0.38 8000 | avconv -i pipe:0 -q:v 1 -vframes 1 SD.png &>/dev/null )
Time of capture on my local network: 0.343s
Let me continue, my goal is to find a way to get a stream or a snapshot to have the video in a domotic software as jeedom / domoticz / etc... ;-).
Enjoy,
nykr95 wrote 02/10/2016 at 21:58 point
alixjg:
That actually worked - for port 9000 - but I am actually getting the low res stream.  I selected that model # in Blue Iris.  Now if I can just get the HD stream - I'm good.
Steve
alixjg wrote 02/13/2016 at 14:01 point
Yeah, sorry I forgot to mention that.  I can't figure out how to get the HD stream or audio.  I came across this the other day when meshare wasn't working for my wife and I.
nykr95 wrote 02/21/2016 at 22:58 point
I decided to sent it back to Amazon.  Too much effort when I can get other cameras the same price online with the same features and they have Onvif or RTSP feeds documented.
alixjg wrote 02/10/2016 at 17:36 point
Hi,
I'm not sure if this is worth looking into or not, but I was able to successfully setup the app "IP Cam Viewer Pro" on my android phone.  I selected "Zmodo ZMD-ISV-BFS23NM" for make and model, entered my IP, port 8000, and the username & password I use for the web interface.  I can view the camera, but I don't think audio is working.
nykr95 wrote 02/08/2016 at 21:13 point
Hi Guys,
I also have a couple of these cameras.  Found this thread searching the net.  I have been trying to figure out if I can use Blue Iris to get the video feed.  I put in the IP address and use port 8000 but I guess I don't have the correct path to grab the feed.  If seems to authenticate but not send the stream.   If you are able to receive it using mplayer - I would think Blue Iris could work.  Any suggestions on what parameters to use?
Regards,
Neil Cherry wrote 02/05/2016 at 14:09 point
Sorry been a bit busy (and I still am). But this is interesting:
http://www.contextis.com/resources/blog/push-hack-reverse-engineering-ip-camera/
A few more things we can poke at to see if we can access things like the voice.
Andreas M. wrote 01/26/2016 at 16:24 point
Since I don't have a ZModo yet, I can not verify, whether this is of interest: https://forums.zoneminder.com/viewtopic.php?f=9&t=18137
It mentions two ZModo models.
Neil Cherry wrote 01/27/2016 at 06:33 point
I took a peak and can't tell what cameras are being mentioned. I see the DVRs but not the cameras.
Neil Cherry wrote 01/18/2016 at 00:29 point
Hmm, replies get a bit funky when you reach the limit ...
Well I though about the binary blob in the mtd (flash) so I wrote this:
for i in 0 1 2 3 0ro 1ro 2ro 3ro block0 block1 block2 block3
do
    echo -n "$i "
    dd if=/dev/mtd${i} 2>/dev/null | uuencode -m -
    echo
done
I tossed that into an expect script that I use to login and run a set of commands when the camera is rebooted. I have that dumped to a file and I'll pull that file apart and uudecode it on my server. I suspect that the mtdXro and mtdblockX files are identical to the mtdX files but I might as well take a look. If I can figure out how to mount the mtd2 as a cromfs image I might be able to get qemu to run and possibly compile some stuff to work with. Right now I'm pretty happy with the cgi program. I hope to have the camera setup tomorrow and start playing with it on a daily basis. :-)
ril3y wrote 01/20/2016 at 20:55 point
Hey @Neil Cherry I was away for a few weeks but now am back and working on this project again.  Would you like me to add you to the project?  Also, I have been trying to figure out the interface to the camera to linux.  Lots of times its like /dev/video but I am not sure on this one.  I very much would like to ignore the App3518 all together.  It seems pretty horrible.
I am working on killing the watchdog timer now too.
Thoughts?
Neil Cherry wrote 01/20/2016 at 23:16 point
Not a problem, I've made really good progress (okay I went a bit nuts). I have a perl cgi running at home and can grab snap shots. I've been doing a lot of poking around and found these of interest:
http://irq5.io/2015/10/30/unpacking-xiaoyi-firmware-images/
http://xiaoyi.querex.be/
http://www.isysop.com/unpacking-and-repacking-u-boot-uimage-files/
http://www.isysop.com/unpacking-and-repacking-u-boot-images-part-2/
I haven't gotten around to investigating them too much yet. At minimum I was hoping I could steal the rtsp application and drop that on the camera. I also found some info on grabbing the bus pirate and pulling the image out of flash (and also put it back, just in case). I still haven't found where they write the data to, hmm..
I think the watchdog needs to stay, but I've been able to kill the App3518 and message and restart them so I can get the correct time (see my page). I'm also fixing an error on the funlux-cap.exp script so that it works properly. I haven't worked with the cramfs and I'm still learning binwalk (worked great on my Amcrest camera).
Neil Cherry wrote 01/16/2016 at 22:49 point
So I spent some more time with the screen shot commands. Turns out the one's I listed below fail if motion occurs. I'm not sure why but I've also discovered that I've had a lot of problems using the pipe:0 option for input. I seem to get varied results at different times (phase of the moon issues?). So with that in mind the current command I'm using is:
$ get_funlux.pl -h 192.168.2.5 -t 2  > video.h264;  avconv -r 25 -y -c:v h264  -i video.h264 -c:v h264 result.mov &&  avconv -strict experimental -i result.mov -vsync 1 -r 25 -an -y -qscale 1 -vframes 1 screenshot_%03d.jpg
The Perl script: get_funlux.pl handles the echo and netcat parts below (I've had some issues with netcat). The result is a video.h264 file (junk really), result.mov (h264, not sure why I use .mov) and a screenshot_001.jpg file. The screenshot_001.jpg is the screen shot. I'm just too lazy to clean up. The get_funlux.pl can be found here (I'll post that later tonight):
http://ushomeautomation.com/Notes/Funlux/get_funlux.pl
http://ushomeautomation.com/Notes/Funlux/funlux.pl
The scripts are licensed GPLv2. The get_funlux.pl is the echo netcool replacement, the funlux.pl is the Apache CGI Perl to generate a snap shot. There will also be a funlux.exp (Expect) script for getting the camera into a given state on reboot. I'll upload that later. Don't expect my best coding, these are quick hacks but they should work.
So more info will be posted here later. :-)
chris wrote 01/17/2016 at 00:28 point
What version is the camera running? Because it very well may be causing the phase of the moon issue. I've got 2 of these both with different versions on them. The camera with v7.4.0.16 seems to be very slow to detect motion and there's no rhyme or reason to it. Sometimes it'll send me a bunch of alerts with nothing and then not detect someone walking right up to the camera. The other camera is running v7.4.0.9 and the motion detection seems a LOT more sensitive and accurate.
The reason I mention it is because as I was watching the cameras console output it was looping the session back to the meshare servers. Basically checking to see if it was connected and getting a heartbeat of sorts. But every time motion was detected the loop was interrupted and it would send 5 or 6 still frames out to the meshare servers. and then it would resume normal operation.
Neil Cherry wrote 01/17/2016 at 16:46 point
---------read configinfo--------
UbootVersion:V7.0.0.0
KernelVersion:V7.0.0.0
RootfsVersion:V7.0.0.0
AppVersion:V7.4.0.9
DeviceName:CH-S1R-WA
HardWareVersion:799990304
SupportInfo:0000011d
I don't have the meshare connection running, I've pointed the device to a non-router so it can't find its way home. What I've seen is if I issue the command to start the video (and convert) that initially it might work. But if I do it immediately again, it fails. Then I attempt a third time with a wait of 30 seconds or so it is again happy. It might have something to do with the above HBs that are sent but I don't know.
I'd love to get my hands on an update of the firmware. Then I could rip into it at my leisure. I've found a few other links that suggest my bus pirate may accomplish what I want. :-)
Oh forgot, I've update the link so the perl script is now there (sorry about that) and I've updated the web page with more information. Of course much more to follow.
chris wrote 01/17/2016 at 22:22 point
Neil, What you are describing seems to mirror what I've seen the camera do when it detects motion. On both my cams they also stop serving video for a second or two when motion is detected. I saw it in the serial output and also watched it on the monitor. It is really buggy stuff.
I'm going to work on extracting the uncrammed firmware from both running cameras tomorrow so we can poke around under the hood.
My main two focuses on this project are to enable a usable rtsp stream so these can be used on one of the many DVR software packages. And to enable local storage. I'll try and post by firmware dumps here if I can get write access to the dropbox. Otherwise I'll have to get them out to the group some other way.
chris wrote 01/16/2016 at 01:06 point
I just grabbed 2 serial sessions off of a new camera. New as in just taken out of the box and never setup.  I'll be uploading them to either a files section or the log once I clean them up. The first one will be the initial boot showing what this buggy little app does for the initial setup and I let it log for about 5 minutes so it would show how it tries to pair with the meshare app on an android phone. Prior to pairing with the app, the camera does trigger an alert in kismet as a suspicious client probing networks but not participating.
The second capture is the pairing session with the meshare app and then the network setup that follows. I'll get these uploaded soon.
Bill wrote 01/06/2016 at 04:55 point
I bought this camera from Frys Electronics and they list it as the Zmodo ZM-SH75D001-WA. The Packing List and label on the shrink wrap also call it the ZM-SH75D001-WA, but the carton and the camera itself only refer to the ZH-IXY1D. This confirms what chris wrote on 12/10/2015 below and the idea that these were rushed out the door.
The Zmodo site also has a Category on the KB page called FUNLUX. There are some references to this Zmodo camera (both numbers) on their "forum". The 2 different Zmodo model numbers add to the difficulty and confusion when searching for info on it.
I can confirm that a generic cell phone charging battery and cable will power the camera with no modifications.
I am not a programmer and can't add much technical help here, but I do want to mention that I can record a live stream from my unit directly to my QNAP NAS. I do it from the IE web GUI by right clicking on the live image and select Record. It records in a proprietary .264 file extension format that can't be played in VLC, MPC, DVDFab Media Player 2 or any other player I have tried. A Russian site I looked at hinted that the Zviewer application from Zmodo can play them, but I have not been able to do that. MediaInfo can read the data and a sample recording looks like this:
Format                                   : AVC
Format/Info                              : Advanced Video Codec
File size                                : 28.7 MiB
Video
Format                                   : AVC
Format profile                           : Baseline@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Format settings, GOP                     : M=1, N=100
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Note that there is no info on duration or Bit Rate, etc.
A readable BMP image CAN be saved in the same manner, just choose Capture instead of Record. The image I saved is 1280x720 and is 2.60 MB in size.
I have very little knowledge of Linux, but I do have a Raspberry Pi and am willing to help out testing with it or Windows if needed.
Hope this info is of use to a few of you.
Neil Cherry wrote 01/09/2016 at 00:07 point
Hi Bill, sounds like you have the same camera. The CH-S1A-WA or ZH-IXY1D or ZM-SH75D001 seemed to be based on the same hardware. The proprietary file format is not unusual, they seem to think it makes there product better (really???). But that's the Windows software and not the camera. The camera streams h264 video. I'm not an expert on video.
I would expect that the Raspberry Pi can run the commands I have used below. I haven't gotten any further on these cameras yet ( my friend gave me yet another, different camera, with PTZ that I've been hacking :-) ). So far I can get that one to give me video and I can start/stop the PTZ controls. That needs a bit more work. :-)
Neil Cherry wrote 01/04/2016 at 21:28 point
I've put all my notes up on my web site (I'll continue to post here also). I thought it would be nice to have the information sorted and tidied up a bit.
http://ushomeautomation.com/Notes/Funlux/index.html
Also I found some information that suggests that the audio might be: g711a (64Kbps), A-Law (64Kbps), or g726 (16Kbps). One can hope :-) I've got a trace with audio being sent from the PC browser and receiving.
Neil Cherry wrote 01/03/2016 at 17:32 point
Single snapshot:
$ echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x50' | netcat -w 2 192.168.24.130 8000 | avconv -i pipe:0 -q:v 1 -vframes 1 screenshot-%03d.png
Neil Cherry wrote 01/02/2016 at 03:54 point
Hehe! Success! I can now see the video stream in mplayer. Not sure how I'll get that into stills or into the browser but I can at least now make use of the camera. :-)
$echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x50' |netcat -w 600 192.168.2.5 8000 | mplayer -fps 24.976 -demuxer h264es -
(soory, fixed that now)
gastonoso wrote 01/04/2016 at 19:44 point
Hi Neil. Congratulations for your progress ! Would you mind explain a little bit the script that you used?  Thank you. Regards.
Neil Cherry wrote 01/04/2016 at 20:56 point
Yes that is a bit of magic. This is quick and dirty programming via the bash command line on my Linux server . :-) I'll later write a program to do this but it will be much more complex but a lot faster. I try to use the command line when I need to toss together a proof of concept (and I stole parts of the commands from @Peter Jerde below, but I upvoted him too).
Short answer:
The echo command sends the magic string into the stdin of netcat, netcat sends it to the camera, the camera begins to stream the video and mplayer displays it on the console of the Linux computer.
Long answer:
The magic string ( '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x50') is what tells the camera to start sending video. There are other magic strings also and I haven't figured them all out yet. The \x55 means translate that to the byte 0x55 in hex. That's a 12 byte string.
The camera is on IP 192.168.2.5 and listening on port 8000 for a command (that string above).
Netcat (or nc on some systems) sort of opens a 2 way pipe between the command line and the camera. It hides the network magic (watch with wireshark to see the magic). The -w 600 tells netcat to keep the connection open for 600 seconds (10 minutes).
The mplayer will play the video. You need to be running X under Linux or Mac,
The fps is the frame per second (25 should work, I was messing around). I'm not sure what the ' -demux h264es - ' options mean exactly yet (other than treat the input as h264).
I'm not sure what to do on Windows.
If you wanted to save the video to a file you can use this command:
$ echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x50' |netcat -w 600 192.168.2.5 8000 > video.h264
That should give you 10 minutes of video from the camera. Then you can use other tools to play the video. I plan on getting the video and images into a browser at some point.
Neil Cherry wrote 12/31/2015 at 23:34 point
I also have a similar camera. CH-S1R-WA (Funlux mini wireless). I'm able to telnet (as per above) into the device and the md5:
# md5sum App3518
3497597d45ee5fd79825db92db1d6564  App3518
I've also found:
http://IPADDRESS/ with admin/111111 as ID and password.
I downloaded the cab file which results in a bunch of binaries and I think it's python source (odd but nice). I see that the device is listening on tcp ports 23, 80, 8000 and 9000 and using UDP ports 5844, 39770 and 8080.
I now also have a sniffer trace of the IE (cab) to camera communication. It's on port 8000 and it appears to be v7409. Unfortunately I'm not sure what to make of the stream yet.
More useful info:
$ (echo -e '\x55\x55\xaa\xaa\x00\x00\x00\x00\x00\x00\x00\x91') | netcat -w 600 192.168.2.5 8000 > video.h264
Gives me this:
$ ls -l video.h264
-rw-r--r-- 1 njc njc 52488 Jan  1 18:09 video.h264
$ file video.h264
video.h264: VISX image file
Well that was interesting, not sure what kind of file it really is but contained inside was my wifi information, in plain text (grrr).
alixjg wrote 12/22/2015 at 12:04 point
I recently purchased and setup a Funlux CH-S1R-WA, but I noticed after I took it out of the box, the back of it says ZH-IXY1D.  It uses meShare as well and appears to be the same camera, just different housing.  http://www.funlux.com/funlux-ip-network-cameras/indoor-ip-camera/720p-hd-wifi-wireless-network-ip-camera-with-audio.html I'm currently using this camera just as a baby monitor, but I'd really like to set it up with something like iSpy in the future.  I'm not of much help here, but I'd really like to see something become of this!
