This dimmer is designed for 12V led strips (anode common). The max output current of each color channal is 3A and the max current of the white channal is about 5A all limited by the size of the pathways of the pcb. The voltage limit is caused by the ldo.
Enrico
Li Wei
Matthew Sheffield
Pratik Makwana
