• CO2 Data fetch
    h4ltsys03/21/2018 at 21:10 0 comments
    the first step of the project is to obtained the co2 level data. To do this, I choose to use the HTTPThing app from thingspeak, that allow to fetch data from every site and make it disponible trough an API.
    The MCU that i choose to use is the well know ESP8266. Thanks to the ESP8266HttpClient library i can simply send a GET request to the thinghttp link and receive the daily data from www.co2.earth.
    #include <ESP8266WiFi.h>
    #include <ESP8266HTTPClient.h>
    const char* ssid = "MYWIFI";
    const char* password = "*******";
    void setup () {
      Serial.begin(115200);
      WiFi.begin(ssid, password);
      while (WiFi.status() != WL_CONNECTED) {
        delay(1000);
        Serial.println("Connecting..");
    void loop() {
      if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
        HTTPClient http;  //Declare an object of class HTTPClient
        http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=YAOX15VANMLMYH4S");  //Specify request destination
        int httpCode = http.GET();        //Send the request
        if (httpCode > 0) { //Check the returning code
          String payload = http.getString(); //Get the request response payload
          String todaydate = payload.substring(62,76);
          String todayco2 = payload.substring(118,128);
          Serial.print(todaydate);
          Serial.print(" CO2 Level: "); //Print the response payload
          Serial.println(todayco2);
          httpCode == 0;
        http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=3TKGGW5Z5CHH7G0S");  //Specify request destination
              String agodate = payload.substring(36,50);
          String agoco2 = payload.substring(92,99);//Get the request response payload
             Serial.print(agodate);
          Serial.println(agoco2);                    //Print the response payload
        http.end();   //Close connection
      delay(30000);    //Send a request every 30 seconds
    However co2.earth only maintain data histories about last year. So for the decade CO2 data i will use  a text file downloaded from noaa server that contain world CO2 data from start of 20th century.
