When the Raspberry Pi Zero was announced, a significant chunk of the hacker world dismissed it for having the same fatal flaw as the other Pis: only one USB host port for high speed I/O.
Network connectivity is a major reason that people base projects around a Pi or other embedded Linux board. The 2B and B+ both have onboard USB hubs providing 4 USB ports and an Ethernet interface, making it easy to connect to a wired network or add on a USB WiFi adapter. But the A+ and Zero do not have this luxury. You need an external hub to get the same functionality, which compromises the size advantage and makes for an unwieldy cable mess.
That's unfortunate, because other embedded Linux boards in similar form factors are at least $50 (Intel Edison). These often are designed for commercial products, and so have hacker-unfriendly interconnects that need a breakout board that drives the cost up even further. What's worse is that alternatives don't have the same online support community that Raspberry Pi has fostered.
What the Zero desperately needs is WiFi that doesn't involve the USB port.
SDIO and HATs
The BCM283x SoCs at the heart of every Pi has two MMC controllers. One of these connects to the SD card slot that the Pi boots and runs its OS from. The other has largely been ignored, but comes out on the HAT connector as alternate functions on GPIOs 22-27. Recent kernel and boot blob changes have enabled these pins to be mapped to the MMC controller that also supports SDIO devices.
SDIO started out as an extension of the SD spec to allow for cards that have functionality beyond flash storage. Some PDAs could be expanded to have WiFi or cameras through SDIO. Although smartphones killed the market for SDIO cards by integrating these common features, the bus still lives on as a bridge between SoCs and WiFi modules.
At the time of this writing, the rpi-4.2.y branch of the Raspberry Pi supports the SDIO interface on the HAT connector well. Simply build and install the kernel and edit /boot/config.txt to include the following line:
dtoverlay=sdio,poll_once=false
This enables SDIO on the HAT connector, and asks it to poll for SDIO cards past the initial driver probe at boot time (more on this later).
Enter the Eagle
In all the excitement over the Zero, I noticed a bunch of questions about using cheap ESP8266 modules as a WiFi bridge. Usually these threads were killed by someone by saying that the SPI interface would constrain the speed too much. Fortunately those questions jogged my memory a bit.
I remembered this blog post showing a decapped ESP8266, noting that in the corner is printed "ESP8089". The post mentioned that ESP8089 is another Espressif part, a commodity SPI and SDIO to WiFi chip. That got me thinking that, if the ESP8089 and ESP8266 are the same die, then there is a good chance that an ESP8266 module could work as an SDIO WiFi adapter on the Pi.
Espressif isn't helpful with ESP8089 documentation, but some Googling landed me at the center of the cheap Chinese tablet universe. That pointed me to a driver in a kernel tree for a specific Rockchip-based tablet that happens to have an ESP8089 adapter, as well as an attempt to break out an older version of the driver as a standalone module to use with ESP8089 in SPI mode.
So there's a driver, and possibly a physical interface between the Pi and ESP8266, but what about firmware?
The ESP8266 we're all familiar with normally boots from an off-chip SPI flash device, and can optionally boot code over the UART. The determination of how to boot (UART vs SPI) is done by GPIO strapping at power-on. Most ESP modules are set so that one pin alternates between booting from SPI flash or the UART. This lets the UART be used to download new firmware to the SPI flash when hooked to a PC and to run from flash when not. But the sparse ESP8266 documentation does mention a third SDIO boot mode, but there is no explanation of how to use it.
It turns out that SDIO boot is intended for the ESP8089. The driver contains a few firmware...
ajlitt
Stephen G
Yann Guidon / YGDES
jacksonliam
Have you evaluated the antenna on this design? It looks like a copy/paste from Texas Instruments. Since your application differs from the TI reference design, it is likely that the antenna performance has changed or possibly tuned off of frequency. If you provide me with a prototype board, I would be happy to impedance match and optimize the antenna for this project.
