24 Volt to 12 Volt step down heat
A project log for Power Supply Plan 24 Volts 300Watt heatpad
Power Supply Plan 24 Volts 300Watt heatpad or higher
films4youFilms4You 05/17/2016 at 11:510 Comments
RAMPS 1.4 etc in a shoebox from 24 Volts so I added a fan and some heat sinks
