I have found local sources of materials for my refractory cement as well as figuring out the quantities I need and the estimated costs. I had previously figured that I would need 2.6 cubic feet of cement but I will plan to purchase enough materials for 4 cubic feet.
Most materials can be purchased in at the local Hardware store but I will have to travel to the north side of Houston, TX for the fire clay which I was able to find here: http://www.ceramicstoreinc.com/ .
I also have created a word document that contains my mission statement and the notes that I take while planning the project and will see if I can get it attached here,
