So lacking any specific dimensions to the type of burner I wanted to build I put pencil to paper and drew some plans. The Burner I wanted to build is based on a Delavan Siphon Nozzle. I liked this because of the clean look and apparent ease of operation. It also will gives me the option of running on waste oil, liquid fuels, or Propane.
I have also assembled a list of components that I will need to build it. For the Preliminary parts list I gathered prices from McMastercarr being as it is a favorite site of mine for general project supplies. The list is also more of a wish list than and actual list and due to the steep price tag I will likely look for cheaper options and suppliers. As a last note I have updated my project notes .doc with this information as well.
http://www.patriot-supply.com/
Delavan Siphon nozzle
Part#30609-8
$24.00
Delavan Nozzle Addapter
Part#17147
$24.00
Feed line | Quantity | Description | Part# | Price | Extended |
Air | 1 | Industrial-Shape Hose Coupling, Size 1/4 Zinc-Plated Steel Plug, 1/4 NPTF Female End | 6534K56 | $1.32 | $1.32 |
All | 4 | Steel 37 Degree Flared Tube Fitting, Adapter for 1/4" Tube OD x 1/4 NPTF Male Pipe | 50695K162 | $1.46 | $5.84 |
All | 1 | Smooth-Bore Seamless Steel Tubing, 1/4" OD, 0.049" Wall Thickness, 6 Feet Long | 9220K321 | $10.46 | $10.46 |
Null | 1 | Standard-Wall Steel Pipe, 2 Pipe Size, 3' Length, Unthreaded | 7750K196 | $46.45 | $46.45 |
Oil | 1 | Compact Extreme-Pressure Steel Threaded Fitting, 1/8 Pipe Size, 90 Degree Male Elbow | 50925K117 | $3.83 | $3.83 |
Oil | 1 | Steel 37 Degree Flared Tube Fitting, Straight Adapter for 1/4" Tube OD x 1/8 NPTF Female | 50695K171 | $1.95 | $1.95 |
Oil | 1 | ISO-A Hose Coupling, Zinc-Plated Sleeve-Lock Socket, 1/4 Coupling, 1/4" NPTF Female | 51335K51 | $21.94 | $21.94 |
Oil | 1 | ISO-A Hose Coupling, Zinc-Plated Plug, 1/4 Coupling Size, 1/4" NPTF Female | 51335K61 | $8.38 | $8.38 |
Oil | 1 | PVC Tubing for Fuels and Lubricants, 1/4" ID, 3/8" OD, 25 ft. Length | 5187K63 | $16.25 | $16.25 |
Oil, LP | 2 | Compact Extreme-Pressure Steel Threaded Fitting, 3/8 Male x 1/4 Female Pipe Size, Hex Head Bushing | 50925K345 | $1.50 | $3.00 |
Propane | 1 | Hose Coupling for Natural and LP GAS, Socket, 3/8" NPT Female, 3/8" Coupler | 6053T11 | $23.25 | $23.25 |
Propane | 1 | Hose Coupling for Natural and LP GAS, Plug, 3/8" NPTF Female, 3/8" Coupler | 6053T12 | $11.18 | $11.18 |
Propane | 1 | Gas Regulator for Propane, CGA #510 Male Inlet, Standard Duty, 1-Stage | 7897A66 | $141.09 | $141.09 |
Propane | 1 | 12 Feet Long Hose for Torch-to-Propane Tank Adapter | 7976A34 | $41.46 | $41.46 |
Propane | 1 | Brass Barbed Tube Fitting for Vacuum, Straight for 1/4" Tube ID x 1/4 Male Pipe Size | 44555K132 | $3.03 | $3.03 |
Total | $339.43 |
