ESP8266 web based temperature sensor
Back to overview
Use an esp8266 to provide temperature data to a web page.
Gary wrote 12/16/2015 at 00:54 • point
This was just one way to mount the device, SInce I wanted to have it in a dusty enviornmnet (stable) I choose to keep it enclosed. I am seeing a slight temp boost when I close up the box. Looks like it a pretty even 8 deg offset, so I might just add an offset variable to compensate. If your not worried about  dust then you can move the DHT11 outside the case or come up with a case that has vents.
Gary wrote 12/16/2015 at 00:51 • point
I have not tested the battery from full charge to empty, but have had it up and running at least 3 days. Right now I am testing a small solar panel to keep the batter charged during the day. The unit is located out in my stable.
Muth wrote 12/15/2015 at 05:44 • point
Very interesting ! Thanks a lot for all these instructions ! How long roughly lasts the 18650 battery of your setup ?
Daan Pape wrote 12/14/2015 at 09:56 • point
I don't see any vents in the box although the last picture is not se clear. In my experience some ventilation is needed to ensure a proper temperature reading. Maybe you can drill some holes in a nice pattern?
