Vibration Switch
A project log for The Smart Letterbox
Attach a device to an existing letterbox that will send a push notification when a letter or package is inserted
Tony KambourakisTony Kambourakis 01/08/2016 at 01:121 Comment
Tried the Adafruit vibration switch (purchased from Core Electronics) to see if it can be used to detect the insertion of a letter/package in the letterbox. It comprises a metal pin with a soft spring coiled around it. When it is moved the coil touches onto the pin, essentially behaving as a switch.
I connected it to a resistor and LED to observe the waveform when it makes contact.
It generates quite a few pulses due to the bounce. It doesn't look like the pulse has a large enough rising edge to trigger the GPIO of the MCU. This needs to be tested.
Here is a shot of the inside of the vibration sensor
Tony Kambourakis wrote 02/07/2016 at 14:22 point
Tests demonstrated this vibration sensor produced a significant enough change to be detected by the MCU input.
