Shaft Drive
12/16/2015 at 03:23 • 0 commentsThe shaft is made from stainless steel hex rod and is pinched between the stepper drive wheel and two guide wheels, the pinch wheel has a rubber sleeve to allow it to grip the shaft. The stepper is also on a pivot and a tension spring puts enough force to allow it to move however it it jamms it will either skip steps or slip on the shaft.
LCD and Speed.
12/15/2015 at 21:56 • 0 commentsFinally the LDC, Speed Controller and Distance Sensor are all working together! I have added a new mode called Random, still needs some fine tuning but the shaft will move outwards a random distance, I was tempted to also add a random speed and velocity into the mix but may leave that for another time.
Boris van Galvin
