Tiny progress
A project log for DYPLED
a thin LED display in SIP module format, much better than TIL311s to visualise your computer buses
yann-guidon-ygdesYann Guidon / YGDES 01/11/2016 at 03:480 Comments
I received SMD resistor networks that pack 4× 0603 × 1K into a 1206 form factor, this will help save a little room here and there. This is the kind of part that, when you start to use it, you wonder why you didn't before...
Delivery of the AT49BV162A : at last! They were worth the wait, I can proceed with the rest...
I should add pull-down resistors on the input data signals...
I'm already thinking about how I'll integrate the design in the #Discrete YASEP. The availability of a 1M×8 chip allows me to just drive the 5th segment with its own decoder, in the P1B Display page. New modes become possible since all the segments will be completely decoded! An octal mode might even be possible...
