Autorouters are for the weak
A project log for DYPLED
a thin LED display in SIP module format, much better than TIL311s to visualise your computer buses
yann-guidon-ygdesYann Guidon / YGDES 08/06/2016 at 22:4312 Comments
I finally completed the place/route work for the module! It took a long time (it started many months ago...) and even though all the parts fit, I wasn't sure the tracks would. Yet there is still a little room under the contrast adjustable resistor. If you're impressed, well, I'm even more impressed that I completed it and respected all the constraints!
Is there an autorouter out there that could do such a crazy job ?
James Newton wrote 08/07/2016 at 05:02 point
Nicely done!
Yann Guidon / YGDES wrote 08/07/2016 at 05:07 point
Thanks !
Let's pray that it is not only nice-looking but also functional :-P
zakqwy wrote 08/07/2016 at 02:44 point
Looks great, well done!
Yann Guidon / YGDES wrote 08/07/2016 at 02:48 point
Thanks ! I know I would love to use it, but do others need or would like to have one as well ?
zakqwy wrote 08/07/2016 at 03:39 point
I don't do much with 16-bit (or 8-bit, for that matter) parallel interfaces.. but I'll definitely keep this in mind if I do..
K.C. Lee wrote 08/06/2016 at 23:33 point
I enjoy the satisfaction of a good hand routed PCB.
Hope you get the FLASH chip programmed right the first time. I always seem to mess up small silly things myself or change my mind after seeing how things works.
Yann Guidon / YGDES wrote 08/06/2016 at 23:42 point
it's inevitable :-)
Yann Guidon / YGDES wrote 08/06/2016 at 23:48 point
and for the Flash contents, i will try to make a prototype :-)
Ted Yapo wrote 08/06/2016 at 23:08 point
But manual routing takes a week? :-P
That's quite impressive.  Nice job!
Yann Guidon / YGDES wrote 08/06/2016 at 23:11 point
In this case, more than a week :-D
I had set the bar very high but if it works, it's more than compensated by NOT having to program any software or deal with any classic programming.
Xylitol wrote 08/06/2016 at 22:58 point
i must say i'm impressed, skill !
Yann Guidon / YGDES wrote 08/06/2016 at 23:02 point
I must admit I could be mad, but I have overcome ! :-D
