Make ready capacitive sensor for Arduino, 3D print
Make ready capacitive sensor for Arduino, 3D printer
Make ready capacitive sensor for Arduino, 3D printer Capacitive sensor FAILS for 3D Printer. I Now use a BLTouch sensor which is Great <a href="http://www.dailymotion.com/video/x3r04j0_capacitive-sensor-fails-for-3d-printer_tech" target="_blank">http://www.dailymotion.com/video/x3r04j0_capacitive-sensor-fails-for-3d-printer_tech</a> Wiring and basic testing of non-contact capacitive sensor LJC18A3-B-Z/AY PNP NC 3-Wires 10mm Capacitive Proximity Sensor Switch DC 6-36V <a href="http://www.dailymotion.com/video/x3h46ml_protomaker-3d-printer-make-ready-capacitive-sensor_tech" target="_blank">http://www.dailymotion.com/video/x3h46ml_protomaker-3d-printer-make-ready-capacitive-sensor_tech</a> Outside diameter: &#x3A6;18 Dimensions: 78 x 30mm/3.07 x 1.18&quot;(L x Dia) Total Length:127cm/50&quot; The detection method: Capacitive Detection range: &#xB1; 10mm (mm) Operating voltage: DC6-36V Output Type: PNP NC(normally closed) 3 Wire Protomaker Black Sp
This uses Tom's Guides
  • 1 × Capacitive Proximity Sensor Switch LJC18A3-B-Z/AY PNP NC 3-Wires 10mm Capacitive Proximity Sensor Switch DC 6-36V
  • 1 × 15K Ohm and 10K Ohm resistors Voltage devider
  • 1 × Solder, heat shrink, wire, etc... Connecting and insulation, Inline conneting
  • This capacitive sensor is RUBBISH
    Films4You11/15/2016 at 19:04 0 comments
    This capacitive sensor is RUBBISH I now use a BLTouch 10000% better than false zero from #capacitive sensor
  • NOTE This FAILED!!!!
    Films4You02/23/2016 at 09:36 2 comments
    It
    a) Seemed to give different distances depending whether it was on the right hand side of the Print bed of the left hand side of the bed.
    b) The LED would flicker some times as it moved from On to Off sensing. On a 3D printer I thing this could cause a problem because when Homing the head touches down the goes back up then back down as a double check. If the On/Off flicker is happening during this time false signals could occur, some video abut this flicker:-
View all 2 project logs
