NOTE This FAILED!!!!
A project log for Make ready capacitive sensor for Arduino, 3D print
Make ready capacitive sensor for Arduino, 3D printer
films4youFilms4You 02/23/2016 at 09:362 Comments
LJC18A3-B-Z/AY PNP NC 3-Wires 10mm Capacitive Proximity Sensor Switch DC 6-36V
It
a) Seemed to give different distances depending whether it was on the right hand side of the Print bed of the left hand side of the bed.
b) The LED would flicker some times as it moved from On to Off sensing. On a 3D printer I thing this could cause a problem because when Homing the head touches down the goes back up then back down as a double check. If the On/Off flicker is happening during this time false signals could occur, some video abut this flicker:-
Films4You wrote 11/15/2016 at 19:06 point
This capacitive sensor is RUBBISH I now use a BLTouch which is 1000% times better than getting false zeros off this capacitive sensor
