Hackaday.io Hackaday.io
Sign up Log in
Cabinet for Arcade Games
Particular cabinet for arcade video games that can be assembled without screws or nails, all simply by clamping the various parts.
vittorio-loschiavoVittorio Loschiavo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
0 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
2.2k
0
13
48
Team (1)
  • vittorio-loschiavoVittorio Loschiavo
Join this project's team
  • Blog
completed project
hardware
2018hackadayprize
Related lists
Video Games
Both retro and novelty. Games, consoles, controllers, gadgets.
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Open Hardware Design Challenge
  • Reinvented Retro Contest
This project was created on 03/13/2018 and last updated 8 years ago.
Description
Particular cabinet for arcade video games that can be assembled without screws or nails, all simply by clamping the various parts. It can be made of plywood, MDF or printed with 3D printer. The size of the cabinet allows you to use a 7 or 10-inch monitor, while as commands it is predisposed to use a joystick and six buttons for the games. On the sides of the cabinet are available holes for installing speakers with 70 mm diameter, Credit and Start button. In the posterior part of cabinet are available the power outlet, USB port, HDMI port for an external monitor, power-on / off switch. As a video game emulator, Raspberry Pi can be used (recommended, given the number of resources available for this application) or more.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Converted vintage film and slide viewers into modern gaming systems.
Project Owner Contributor
Vintage film viewers as RetroPies
martin-burlusMartin Burlus
Full RetroPie functionality via a Raspberry Pi Zero 2w with the iPod clickwheel + bluetooth, wifi, and micro-usb charging
Apple Game Boy: 2004 iPod running RetroPie
russell-tabataRussell Tabata
Making video recorder for IP-cameras in retro Atari XC12's case.
Atari XC12 becomes video recorder
iot4ciot4c
Play the classic arcade game pong against a friend or against the computer!
Micro Pong
ghani-lawalGhani Lawal
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Cabinet for Arcade Games", please tell us the reason.
Send message
Remove Member
