System Design
A project log for Voice Controlled Raspberry Pi
A program for custom voice commands to the Raspberry Pi. Make your RPi send emails, play videos, check the weather, and more using speech.
steven-hicksonSteven Hickson 08/21/2014 at 05:020 Comments
Here is the setup of how voicecommand works.
You just easily add whatever custom commands you want to the config file and it does all the rest. For example, if I have a script called lights_on.sh that turns lights on, I can edit the config file by typing voicecommand -e, press enter, and then add:
~on=/home/pi/lights_on.sh
Then save and exit.
This means if I say "lights on" or "turn on", voicecommand will run my script for me.
Easy!
