Voicecommand image file download
A project log for Voice Controlled Raspberry Pi
A program for custom voice commands to the Raspberry Pi. Make your RPi send emails, play videos, check the weather, and more using speech.
steven-hicksonSteven Hickson 08/25/2014 at 19:010 Comments
http://stevenhickson.blogspot.com/2014/08/voicecommand-image-file-and-controlling.html
Here is the link to download a Raspberry Pi A/B/B+ image file that has voicecommand installed already. It also has wiringPi and pilight installed to help you control your electronics.
You can find instructions for how to put this on your SD card here:
http://elinux.org/RPi_Easy_SD_Card_Setup
