1st things first: Probe compensation
A project log for Tektronix MSO2024B Oscilloscope Review
Element 14 is running roadtests and I was lucky to be able to test and review a Tektronix MSO2024B Oscilloscope.
magicwolfiMagicWolfi 03/27/2016 at 13:400 Comments
All 4 probes were just a little bit off with their compensation, which was easily fixed by clipping the probes to the compensation port at the bottom right of the front panel and adjusting the compensation network with the little screwdriver through the hole in the probe socket.
Ch4 before compensation
CH4 after compensation
