Problem A: Infrastructure
Problem B: Disaster Relief Management
Problem C: Construction and Landscaping
Problem D: Non-Terrestrial Construction
Solution
Goals
Tier 1
  1. Robot with modular attachments that enable it to serve various functions
  2. Cheap base model that can be produced in quantity and has basic motion, communication, and sensor capabilities
  3. Assignable roles so that broken robots can easily be replaced by spare units or units can be re-assigned based on need
  4. Teleoperation with visual data so that users can get direct feedback about the status of the project’s target
  5. Limited physical intervention required by users
  6. Ability to direct movement and basics tasks to be performed by the robots
Tier 2
  1. Modular attachments can be swapped autonomously
  2. Dynamic role allocation so that the robots automatically determine the best distribution to get a task done efficiently
  3. Coordinated motion so the robots can be given simple direction to accomplish group behavior
Tier 3
  1. Machine learning can automatically flag problematic inspection data
  2. Augmented reality data so that the users can see the project target and the current progress side by side
  3. Advanced autonomy with the robots having the capabilities to perform a great deal of tasks with little user control required
Specifications
Sensors
Communication
User Interface
Job Allocation
Potential Attachments
Milestones
1. First Functional Prototype
2. Attachment Prototypes
3. Prototype Swarm
4. Survey and Analysis Demo
5. Repair Demo
6. Construction Demo
