Improve accuracy
A project log for D.I.M.E.R PROJECT 6 DOF Robot Arm
This is my robot arm, with recycled materials, can pick 2 Kg and costs around 100$
antonio-regueiraAntonio Regueira • 04/23/2016 at 17:20•0 Comments
On previous video you can see that the accuracy is very poor, so i'm working now on it.
I think that the problems is the shoulder (becasue i use ropes to transmit motion).
I need to change it to gt belt and improve the movement of the motor shaft.
[25-4-16] i changed ropes to belts and added a new spindle. you can see the explain at the instructions.
