Project finished
A project log for D.I.M.E.R PROJECT 6 DOF Robot Arm
This is my robot arm, with recycled materials, can pick 2 Kg and costs around 100$
antonio-regueiraAntonio Regueira • 12/11/2016 at 22:50•0 Comments
Hello!
This is it. The last entry I will make on the D.I.M.E.R mk1 project. A couple of weeks ago I started thinking about the design of the second version, at the moment mk2, more powerful, bigger, more precise and totally replicable so that anyone can build it. As soon as i design something i will publish it here.
I dont want to closed this project without uploading some videos, in the first one i programmed some movements, the second is from another perspective and the third is about the detail of the gears, I hope you like them.
See you soon!
