Let there be sound?
A project log for Room Assistant
A project for an voice and gesture controlled
james-wynhoffJames Wynhoff 03/26/2018 at 18:450 Comments
root@orangepione:~# speaker-test speaker-test 1.0.28 Playback device is default Stream parameters are 48000Hz, S16_LE, 1 channels Using 16 octaves of pink noise Rate set to 48000Hz (requested 48000Hz) Buffer size range from 256 to 524288 Period size range from 128 to 65536 Using max buffer size 524288 Periods = 4 was set period_size = 65536 was set buffer_size = 524288 0 - Front Left
Oops, looks like I flipped the speakers though!
