CPU stable!
A project log for Room Assistant
A project for an voice and gesture controlled
james-wynhoffJames Wynhoff 03/28/2018 at 22:390 Comments
As per the last post I changed the CPU to run at a fixed speed, and here is the output of cpufreq-info now :)
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: cpufreq-sunxi
  CPUs which run at the same hardware frequency: 0 1 2 3
  CPUs which need to have their frequency coordinated by software: 0 1 2 3
  maximum transition latency: 2.00 ms.
  hardware limits: 1.20 GHz - 1.20 GHz
  available frequency steps: 60.0 MHz, 120 MHz, 240 MHz, 312 MHz, 408 MHz, 480 MHz, 504 MHz, 528 MHz, 576 MHz, 600 MHz, 624 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 816 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.44 GHz, 1.54 GHz
  available cpufreq governors: interactive, conservative, ondemand, powersave, userspace, performance
  current policy: frequency should be within 1.20 GHz and 1.20 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency is 1.20 GHz (asserted by call to hardware).
  cpufreq stats: 60.0 MHz:0.00%, 120 MHz:0.00%, 240 MHz:0.00%, 312 MHz:0.00%, 408 MHz:0.00%, 480 MHz:0.00%, 504 MHz:0.00%, 528 MHz:0.00%, 576 MHz:0.00%, 600 MHz:0.00%, 624 MHz:0.00%, 648 MHz:0.00%, 672 MHz:0.00%, 720 MHz:0.00%, 768 MHz:0.00%, 816 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:0.00%, 1.06 GHz:0.00%, 1.10 GHz:0.00%, 1.15 GHz:0.00%, 1.20 GHz:100.00%, 1.25 GHz:0.00%, 1.30 GHz:0.00%, 1.34 GHz:0.00%, 1.44 GHz:0.00%, 1.54 GHz:0.00%  (1)
analyzing CPU 1:
                  within this range.
analyzing CPU 2:
                  within this range.
analyzing CPU 3:
                  within this range.
