PCBs arrived & assembled
A project log for megaminimidi
Mini USB MIDI controller with ATMega328P
sprospro 12/18/2015 at 07:230 Comments
The PCBs arrived from OSHPark and came out perfectly to spec, as usual. The only issue was my own oversight, forgetting the pull-down resistors for the button pads. The solution was easy enough:
