sotto struttura_fixed.stlfile .stlStandard Tesselated Geometry - 5.38 MB - 10/21/2018 at 15:47 |
ingranaggio piccolo.stlfile .stl of Pinion with diameter 16 mm and 10 teethStandard Tesselated Geometry - 1.71 MB - 10/21/2018 at 15:46 |
Standard Tesselated Geometry - 758.68 kB - 10/21/2018 at 15:45 |
Standard Tesselated Geometry - 774.50 kB - 10/21/2018 at 15:45 |
chiusura sotto struttura_fixed.stlfile .stlStandard Tesselated Geometry - 695.59 kB - 10/21/2018 at 15:45 |
PortaMotoreBarreBase_fixed.stlfile .stlStandard Tesselated Geometry - 1.03 MB - 10/21/2018 at 15:45 |
ingranaggio grande_fixed.stlfile .stl 67 mm diameter toothed wheel and 44 teethStandard Tesselated Geometry - 246.76 kB - 10/21/2018 at 15:44 |
Chiusura motore_fixed.stlfile .stlStandard Tesselated Geometry - 828.60 kB - 10/21/2018 at 15:44 |
PortaMotoreBarreCentrale_fixed.stlfile .stlStandard Tesselated Geometry - 649.79 kB - 10/21/2018 at 15:44 |
Guida x Taglio Gronda.stlfile .stlStandard Tesselated Geometry - 855.36 kB - 10/21/2018 at 15:43 |
ChiusuraPale 4 pz_fixed.stlfile .stl, you need 4 pcs of thisStandard Tesselated Geometry - 62.88 kB - 10/21/2018 at 15:43 |
block diagram.jpgblock diagramJPEG Image - 255.43 kB - 04/25/2018 at 08:15 |
