Macro photo lighting
Foldable 80W LED lighting for macro photography and video recording
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This lighting consists of two FR4 pieces (39×21 and 39×28 cm) and a total of 10 m of 5050 white LED strips. Side brackets were made of 3 mm thick FR4, 16 mm wide, and the bottom of 5 mm thick pertinax. A total of 80 W of Led light gives about 2350 lux at the table surface, which is enough for about 1/100s f/5.6 with 100 ASA. The unit is foldable, so I keep it in my library, where it consumes only 45 mm of space. I still didn't build the controller, so there is no light power regulation and LED overpowering for flash effect.
