border bytes
A project log for itanimulli code crackers
cracking the code of the itanimulli riddle
moritz-walterMoritz Walter 12/13/2015 at 11:302 Comments
Are bytes still bytes if they don't mean anything? That's beyond my philosophical horizon, but we have some bytes to decipher here:
@davedarko suggested to use the signs of the symbols (=borders) to build some bytes, while @alpha_ninja mumbled somthing about unicode, so let's look into that, those are the bytes:
01001011
11110000
10110010
00000100
00011010
10101100
00000110
01001111
11101011
11110000
11011110
11010001
01001011
11110000
10110010
00000100
00011010
10101100
00000110
01001111
11101011
11110000
11011110
11010001
01001011
11110000
10110010
00000100
00011010
10101100
00000110
01001111
11101011
11110000
11011110
11010001
01001011
11110000
10110010
00000100
00011010
10101100
00000110
InvertedOrderUnicode
LSBFIRSTÿðþÿÿþÿÿøðüüÿðþÿÿþÿÿøðüüÿðþÿÿþÿÿøðüüÿðþÿÿþÿ
~LSBFIRSTþÿÿàøÿàþÿÿÿÿþÿÿàøÿàþÿÿÿÿþÿÿàøÿàþÿÿÿÿþÿÿàøÿà
MSBFIRST´MûåSù°!.´MûåSù°!.´MûåSù°!.´MûåSù
~MSBFIRSTKð²¬OëðÞÑKð²¬OëðÞÑKð²¬OëðÞÑKð²¬
Well.. unless these are some kind of elb-writings, I guess it's not unicode. However, maybe we could read it with the right key to decrypt it. For a byte key, there are only 255 possibilities, right? Let's try them all..
Error 413
Couldn't post them all due, too much for had.io. It's mostly rubbish anyway. The key probably has more than 8 bit.
davedarko wrote 12/13/2015 at 12:03 point
maybe it decodes the 12x12 xor tyle somehow? 12 is way to dominant.
Moritz Walter wrote 12/13/2015 at 12:15 point
That's possible, I have to test that. Although this would mean that this 12x12px tile decodes the noisemap whereas the decoded noisemap, on a symbol level, decodes the tile again. That is exactly the type of recursive fractalism my prof warned me about @_@
