Right-to-Left
A project log for itanimulli code crackers
cracking the code of the itanimulli riddle
stephenstephen 12/18/2015 at 05:560 Comments
@andyhull suggested interpreting the messages top-down reading from right-to-left instead of my left-to-right instinct. That would make the decoded messages:
Red Message:
A novice came to a master
A novice asked how to find
A solution to riddles hard
A reply from a master was
A novice should search through sand
A novice should so find a boulder
A novice should search through Air
A novice should find the sky
A novice should search through water
A novice should so find the river
A novice Was enlightened
Green Message:
Reading this text just right now
this is the wrong place
Blue Message:
(empty?)
