- milled cab rail enclosure for EN50022 DIN rails
- prototyping plate - fits perfectely in the enclosure
- all Arduino pins are connected to marked pins beside the breadboard
- 4x 2-pin terminal blocks
- 2x 3-pin terminal blocks
- sockets for the Arduino Uno, 101 and zero
- sockets for an optional shield (directely conneted to the Arduino)
- pcb contains a layout for a 12V/1A voltage regulator
- reset button
