Litar: LiDAR Air Guitar
Compact, handheld air guitar with four LiDAR strings and Bluetooth
Man has always enjoyed jamming to their favourite riffs and solos with their imaginary Air Guitar ever since the age of fire. The unfortunate downside to this form of music generation is that while it releases endorphins, you can't actually make any useful sounds from it.
Introducing the Litar, a you beaut wireless air guitar. Four individual LiDAR air strings capture your strums which allow different neck positions and strings to be played. Along with a low latency input and Bluetooth MIDI interface, you can jam away or play with the finest control on your phone or laptop.
The Litar has a simplified, but versatile pressure sensitive chord interface, that allows for advanced control and aftertouch expression. Coupled with a MIDI connection as well as an Arudino development environment, the musical possibilities are many.
This project builds on from the MappyDot from last year's Hackaday prize.
  • MappyDot Plus Testing
    Blecky3 days ago 2 comments
    As part of the new button case design, the Litar will also be getting an upgrade to the MappyDot Plus we have been testing, which uses the brand new VL53L1x sensor:
    The new sensor offers better ambient light immunity and an adjustable field of view. This will hopefully allow us to change the size of the strings programmatically and offer better string strumming recognition in noisy environments.
    The MappyDot Plus will be available on Tindie shortly -
  • Designing Ergonomic Buttons
    Blecky4 days ago 0 comments
    The first Litar prototype used some 2D hall effect joysticks (with button click) as a demonstration to enable advanced chord control, vibrato as well as ambidextrous control:
    These joysticks were based on the AMS Easypoint N40P107 assembly which uses the AS5013 two-dimensional magnetic position sensor. These are great little compact assemblies, however unfortunately the manufacturer has decided to no longer make these and leave it up to the product designers to make their own magnetic pointer with the position sensor.
    This left one of two options, either make your own pointer assembly, or move to a low profile analogue joystick instead. Low profile analogue joysticks with a button click are unfortunately difficult to find it turns out, unless you want large quantities of them (like the ones in the 8bitdo pro controllers):
    I set that problem aside for another day and continued to play further with the Litar...
    After a while and letting different people play with it, it was found that lateral motion in your fingers on something you are holding onto with the same hand was not only difficult, but actually caused a fair bit of strain after a short amount of use. I tried moving the buttons around in the case to make them more ergonomic, but they were still difficult to play and removed the ambidexterity of the controller.
    So I set out to design something different. I wanted to be able to still do vibrato, so I needed a linear sensor of some sort, preferably with some sort of pressure control. Why not a linear hall effect sensor with springs and a simple rectangular button?!
    This sort of setup does simplify the chord input a fair bit, but it does still give you varying levels of control input and can still be waggled for vibrato.
    Here's a cutaway of what I came up with:
    The linear hall effect sensor sits on a PCB, as does two springs on each side of the button. The button moves freely in the hole of the case and is held there by the springs. There's two stoppers on the button part that hits the PCB as it comes down and these stoppers could press a momentary switch. There's a magnet in the center of the button as well.
  • How do the Strings Work?
    Blecky6 days ago 0 comments
    The sensor array on the Litar has been designed to allow for the lowest latency and best accuracy possible when obtaining a string interaction. Each string has a specific geometry that allows them to be easy to play and makes them large enough to pluck.
    The sensors are aligned in such a way that three sensors see a single string in space; two sensors define the string border and a third sensor obtains the string distance. This enures that you don't get miss plucks and it also allows the strings to be packed tighter together over one or two sensor setups (the sensors have a 25 degree field of view). To visualise this, the image below shows the sensor field of views, with the grey areas highlighting the virtual strings:
    To obtain the strings, the data from the sensors is brought into an array of sensor distances over time and placed through a rapid-change detection algorithm. The algorithm scans each combination of sensors which create a string and then obtains the correct distance for the string being plucked. It does this by looking at the most recent value as well as its history to determine which string has been plucked, with the latency of a single distance measurement. With this you can also obtain entrance to the string area velocity information, without increasing latency.
    And that's how the Litar gets its strings.
View all 3 project logs
Est wrote 2 days ago point
Your Idea is great! clever how you arranged the distance sensors. Time ago I was working on a project that i have abandoned with a IR distance sensor and a dsPIC that plays a sound.
I am looking forward to see a video of it in action as I am curious how it sounds.
great project!
Charlie Lindahl wrote 3 days ago point
Do you have a video of someone playing this instrument somewhere? Searching YouTube was an exercise in futility (there is SO MUCH STUFF there!).
Blecky wrote 2 days ago point
I should have a video this weekend for it working with the new Vl53L1x sensors :)
I was having issues with the previous prototype when I added the hall effect joysticks, as these were I2C based and were sharing the same bus as the sensors on an I2C hub (the joysticks had the same address) which added a bit of latency.
The new hall effect sensors use an onboard ADC instead and the I2C is used exclusively for the sensors, so it's much nicer.
Gray wrote 3 days ago point
Ohhhh this is so awesome!!! Well done!
Cheers Gray, it's been a pretty fun project so far. There's a couple of things to iron out, but the technical side of things is going pretty well.
jean.perardel wrote 03/14/2018 at 10:21 point
haha, great idea !
it looks amazing :)
Blecky wrote 03/14/2018 at 10:31 point
I saw the Musical Instrument challenge and definitely had to enter. It's still a prototype, but everything is working well. Unfortunately I'm not a musician, so I've focused on the hardware side with things like getting the latency down. But the strings strum and the Bluetooth, tooths.
