Idea: More LEDs - More Colors
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
AlexAlex 02/15/2016 at 20:131 Comment
Some time ago while talking with someone else about this project, the idea came to use RGB LEDs. And there are small suitable RGB LEDs available: 0404 RGB LEDs. So this is what I came up with: 21*8 RGB LEDs ( =168 RGB LEDs or 504 single LED chips):
Problem here is how to control so many LEDs? I am not sure yet but I am planing to multiplex the lines. And driving the columns via some (21*3=63 Bit!) shift registers. I am also thinking of using a Microcontroller which is faster than a ATmega to get a acceptable refresh rate on the Matrix.
The PCBs measurements did not changed much. The goal is still to fit this and a control PCB of the same size into 5x5cm:
Because this project is still in early stage it is possible that I will return to a single color version ( or never built one ).
de Éhipu wrote 02/15/2016 at 20:51 point
Check out #Tiling Pixels if you want to pack them tighter :-)
