tiny LEDs
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
AlexAlex 03/11/2016 at 15:002 Comments
in reallife these 0404 RGB LEDs are very very small: (the Grid in background is 1mm)
soldering this one on the bread board did work unexpected easy. The PCBs for this project did not arrived yet, but the stencil did arrived. I am happy about the decision ordering the stencil. With it soldering the LEDs could be possibel.
Yann Guidon / YGDES wrote 03/11/2016 at 15:26 point
And you want to solder 384 of them :-)
Alex wrote 03/11/2016 at 15:47 point
There are only 128 RGB LEDs. But each does have three LED chips inside: This is the reson for the 384. But also the 128 LEDs are much. The stencil should help but, manual pick and place should take some time.
