PCBs, stencil and parts orderd
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
alexAlex 02/22/2016 at 16:317 Comments
I did just orderd the last missing parts. Now everything should be ordered to built one (or two perhaps)! I did also ordered a SMD stencil for the first time. With this the solder paste dispensing should be faster and better. And only the LEDs do have 512 pads. For the PCB I did chose black solder mask this time to get high contrast to the LEDs.
Roman wrote 03/12/2016 at 14:42 point
I see, it's good to know. Thanks.
Roman wrote 03/12/2016 at 00:55 point
What files did you use to produce the stencil? The reason why I am asking, in my 12-13 years of PCB design I saw stencil only once. I have no clue how they are produced. Thanks in advance for your answer.
Alex wrote 03/12/2016 at 12:59 point
I did just upload the eagle .brd file at OSHStencils.com  That was it. Quite easy.
davedarko wrote 03/11/2016 at 19:50 point
I want to stand behind you and breath in your neck when you solder this! Or you could film the complete progress ;) Really looking forward to see this LED matrix in action!
Alex wrote 03/11/2016 at 22:54 point
I hope that it will be finished until Belgrade. I am not sure because there is also some software to be written, but taking this to Belgrade would be awesome.
davedarko wrote 03/11/2016 at 23:13 point
almost always when you write something like this, it's done by tomorrow, so we'll see ;)
Alex wrote 03/12/2016 at 13:01 point
First I have to get the PCBs. They are not here yet. So tomorrow or today is impossible.
