new LEDs are working & new control board layout
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
alexAlex 04/17/2016 at 18:093 Comments
The new LEDs are the right ones. Now at least the LED PCB do work. Here is a picture of the soldered LED PCB:
I also redesigned the control PCB: Now the bigger SOT23-6 Transistors do fit and it is inside of OSH-Park's Manufacturing specifications. The new board for the contol PCB are already orderd. So I hope I will have a first working prototype soon.
Roman wrote 04/17/2016 at 21:26 point
PCB is looking good. I am sure this display will be fun to play with.
davedarko wrote 04/17/2016 at 18:16 point
that is such a beautiful display! is the pin spacing 1.27mm? I think I need a coin or fruit for reference.
Alex wrote 04/17/2016 at 18:25 point
Thanks!
Yes the pin spacing is 1.27mm/50mil. As reference there is also the 1mm grid on the paper in the background. But you are right a coin (or banana) would me more obvious.
