Dimensions
A project log for Digibone
A digital instrument with all the flare of a trombone, with the power and flexibility of an MIDI instrument
craig-hissettCraig Hissett 04/01/2019 at 16:331 Comment
I've put a bit of thought into the pieces I'll need to build a suitable frame out of aluminium extrusion.
It'll look cool, plus give me a nice, easy to assemble/adjust frame. It'll be nice to use the channels to run cables too. I've decided to target 15mm x 15mm extrusion as it's small enough to hold comfortably without being too flimsy.
Dimensions based on 15mm material
Slide Section calculations
400mm - slide space (360mm travel [60mm between positions], +40mm for tolerance? Can be adjusted with another inserted piece?
+15mm - for the 'water key' brace
+15mm - for handle
+50mm - for mouthpiece area
Top Section calculations
200mm - to form the shoulder mount.
+15mm - for top bar
+15mm - for brace bar
Parts to order
480mm bar x 2
230mm bar x 2
100mm bar x 4
All in all it'll give me an instrument length of  ~ 74cm once the two half pieces are joined together - nice and small, but enough space to mount everything and get a decent slide area.
Now i just need to find a cheap supplier of 15x15 extrusion :)
Craig Hissett wrote 04/04/2019 at 13:06 point
Update - I am finding 2020 extrusion to be more readily available.
I think I will adjust my list to:
500mm x 2
250mm x 2
100mm x 4
The rounding up of the lengths will allow for the extra 5mm on each of the 100mm bracing bars.
